Question how to center
- jazzking2001
PW test12
#whitebox div {
text-align:left;
Comment-out, or delete, the line I've highlighted in red above. Although it will fix your Kunena issue, it will create other problems with the rest of your site. Because the information only appears for a few seconds, and because this intermediate screen will be eliminated in a future version, I wouldn't agonise over a solution.
- jazzking2001
is there a way to avoid that screen altogether?
i mean after you post, you jsut get taken back to the forum instead of waiting 4 seconds or whatever on the page i was trying to center
This question has been asked and answered before. I'm sure, with a bit of patience, and if you persevere, you will find the answer. Try looking for "return to forum" or "auto return" or something like that.Is there a way to avoid that screen altogether? I mean after you post, you just get taken back to the forum instead of waiting 4 seconds or whatever ...
- jazzking2001
i found it
www.kunena.com/forum/146-solved-hacks-tr...edirect-back-to-post
will try it now >.<
again thanks for the help
