- Thank you received: 1
Please read
Question Options for Customizing Subforums?
15 years 10 months ago #78626
by Decret
Replied by Decret on topic Re: Options for Customizing Subforums?
The following user(s) said Thank You: regdomain
15 years 7 months ago #90025
by joelouw
Replied by joelouw on topic Re: Options for Customizing Subforums?
Hi
I read all the post now regarding custom icons in the categories with the correct ID number and and and - Yet I still don't get mine to work.
I noticed that the folder path to the icons are almost changing with every Kunena upgrade.
I USE 1.6.3 - Here is my forum: http://localhost:8888/thombesafari/index.php?option=com_kunena&view=listcat&catid=0&func=listcat&Itemid=291
Now I noticed that images and path it is directing it to get the images from are: root/components/com_kunena/template/default/images/icons/folder_nonew.png
Now this is where it is getting my images from: I also tried to put images in the root/media/kunena/category_images but had no luck.
COULD SOME OE PLEASE TELL ME WHERE TO FIX THIS?????
15 years 7 months ago #90108
by joelouw
Replied by joelouw on topic Re:Options for Customizing Subforums?
sozzled
I am sorry, I did not niticed that I posted the last post on 2 places in the same forum, at the time I had more than a few post, tabs and browsers open and could not keep track anymore - I was multitasking a bit at that stage.
Here is my screen shot with firebug, please not where the page is getting the icon files from.
The problem is I don't even have this {joomla_root}/media/kunena/category_images folder.
What should I try to do.
15 years 7 months ago #90117
Replied by sozzled on topic Re: Options for Customizing Subforums?
joelouw: Please create a new topic, in the
K 1.6 Support
category, with the subject "Missing ../media/kunena/category_images folder". Please post your K 1.6 configuration report and we will see what you may need to do.
The image that you gave in your message give ambiguous results. Please do not ask me to try to read a small image. Highlight the area you want us to look at and write the text of what you see in your message.
