Question Style Not Working
16 years 8 months ago #28787 by KariMitchell
Replied by KariMitchell on topic Re:Style Not Working
Hi Rich, thank you. I will see if I can do this, I guess it's all done in PHPMyAdmin. ? I am a little scared as I dont have much experience here - but I will see what I can do! Do I only need to backup the jos_fb tables?
THanks so much.
16 years 8 months ago #28788 by KariMitchell
Well - I tried uninstalling Kunena, emptying the jos_fb tables, and reinstalling. No luck. Then I tried uninstalling - DROPPING jos_fb tables, and again no luck. :( Any other ideas? Thanks so much, Kari
16 years 8 months ago #28795 by rich
Replied by rich on topic Re:Style Not Working
My gut instinct is that the issue is not with Kunena - but possibly with Joomla itself
It may be true that, you have a conflict with modules. Your login modules operates not correct. Are you installed also another extensions?
Please to deactivate this all and look again.
16 years 8 months ago #28806 by KariMitchell
I wonder if it has anything to do with full paths or utilization of the IP address (domain not pointed yet)?
I can't uninstall all the extentions/modules - and have no idea what you mean by login not working - we havnen't really done anything spectacular as far as lots of components and modules and I just need something that will display properly.
Time to create page: 0.420 seconds
