Question Style Not Working
16 years 8 months ago #28471 by KariMitchell
Hi, Just installed Kunena Forum 1.55 on Joomla - and while it appears to be 'working' - there is no default template or style appearing - can see it here:
SvelteLife Forum
I have tried uninstalling and reinstalling - and I've used Kunena before and it worked great - this one installed great all times, but the style for the default templates just isn't kicking over. I've checked the configurations and all seems in order, are there any other ideas?
16 years 8 months ago #28492 by rich
Replied by rich on topic Re:Style Not Working
Welcome KariMitchell!
Please go Backend > Kunena Configuratin > Frontend. "Use Joomla Style?" must specify "no".
Regards
16 years 8 months ago #28550 by KariMitchell
Replied by KariMitchell on topic Re:Style Not Working
Hi Rich, Thanks so much - :) I appreciate any help.
I did go in (already) and specify "NO" Under Use Joomla Style. I just double checked it - it's still set to "NO".
My gut instinct is that the issue is not with Kunena - but possibly with Joomla itself - as there are other weird things going on. But I can't be sure as I'm not a Joomla expert - but my gut feelings are usually pretty good. Every other time I've used Kunena forum - it's worked great and very easily.
16 years 8 months ago - 16 years 8 months ago #28592 by rich
That is joomla-style, look screen.
Please go to your database, jos_fb_config and check the following.
Regards
Last edit: 16 years 8 months ago by rich.
16 years 8 months ago #28632 by KariMitchell
Hi Rich, yes - it does look like default style. I went into PHPMYADMIN, and added these lines in the jos_fb_config - but I may not have done it right, do I uncheck "null"? And do I insert them as 'rows'? I've not used PHPMYADMIN much before. I did attempt it though, it said it entered one row, but I don't see any changes. :)
Should I drop the jos_fb tables, uninstall and reinstall Kunena forum again?
16 years 8 months ago #28635 by rich
Please try again
1. to make backup from your database
2. to uninstall Kunena
3. to clear jos_fb_tables
4. to install Kunena again
Regards
Time to create page: 0.263 seconds
