Question Getting up to speed from 1.5.11
15 years 11 months ago #77200 by shanepitre
Hello All,
I am a rookie in the world of website maintenance and hope you can help me out:
I have Kunena 1.5.11 and want to update it to 1.6.1.
I meet all system requirements.
Here is my question:
Do i need to update to every upgrade between 1.5.11 and 1.6.1?
If so what are the exact upgrades i need to update to? It is hard to find as there are many files...
...or can i update directly to 1.6.1?
Thanks for your help.
15 years 11 months ago #77218 by @quila
you can upgrade directly to Kunena 1.6.1, but we recommend to do this on test site and check if all works well and if there are no problems you can do this on your live site.
The best way to test is to create copy of your site on the same server where is hosted your live site.
Regards
15 years 11 months ago #77238 by Mortti
@quila wrote: The best way to test is to create copy of your site on the same server where is hosted your live site.
...and read also this post Before you install Kunena 1.6 - check list
The following user(s) said Thank You: @quila
15 years 11 months ago #77966 by shanepitre
Thanks so much guys and happy holidays!
