Question help with install
16 years 6 months ago #47159 by coder4life
Replied by coder4life on topic Re: help with install
Hello misterdj, are you using a hosting provider or local computer installation for your joomla install.
Sounds like you have a permissions issue. This is very true if you are using an installation like XMAPP which does not always play nice with permission issues.
@xillibit, just wondering would it be better to have permissions on 755 on those associated directories, otherwise you leave those extrememly wide open. Just a suggestion
16 years 6 months ago #47166 by misterdj
Replied by misterdj on topic Re: help with install
xillibit wrote:
Do you have the safe mode on off ?
What is your php version ?
What is your joomla! version ?
Check that these directories have the permissions on 777 :
/components
/modules
/language/en-GB
/administrator/components
/administrator/modules
/administrator/language/en-GB
Do you have the safe mode on off ? - dont't know, where do I've got te look?
What is your php version ? - by my webhost I see phpmyadmin 2.9.2
What is your joomla! version ? - 1.5.16
For that safetything you've got to help me, because (as you noticed) I'm a bit of a noob on this.
16 years 6 months ago #47168 by xillibit
Replied by xillibit on topic Re: help with install
Look in your phpinfo and search for safe_mode
This is phpmyadmin is different to you php version, you will see that too in the phpinfo
Do you have checked the permissions of joomla! directories ? You can look in joomla! backend in Help -> system info -> directory permissions
16 years 6 months ago #47216 by misterdj
PHP Version 5.3.2
Cache Directory - Writable
Log Directory - Unwritable
Temp Directory - Unwritable
Can there by a problem with this settings?
16 years 6 months ago #47229 by xillibit
And for others directories ?
It's important to know if the safe_mode is on or off, do you have looked for this ?
16 years 6 months ago #47235 by misterdj
All the directories are writable accept for:
[/quote]It's important to know if the safe_mode is on or off, do you have looked for this ?[/quote] As far as I can see stands the safe mode: off
