Question Vbulletin to Kunena, jos_fb_messages
16 years 2 months ago #39338
by dany31
Replied by dany31 on topic Re:Vbulletin to Kunena, jos_fb_messages
ok Matias, thank you very much
Do you know mysql command to copy record ? for example to populate jos_fb_messages_text with id and text from vb table. For the moment I use export/import in csv but if is possible with mysql, is faster... sorry for my english, I hope you can understand
16 years 2 months ago #39371
by xillibit
Replied by xillibit on topic Re:Vbulletin to Kunena, jos_fb_messages
I don't know what you mean by copy record, but for insered something in a table use the sql instruction :
INSERT INTO my_table (col1,col2) VALUES(15,'texteeazrteaz');
16 years 2 months ago #39373
by dany31
thanks xillibit, ok with you, but I would want to insert records from other table.
For example :
TABLE_1
'id' 'content'
1 content1
2 content2
3 content3
4 content4
TABLE_2
'id' 'content' 'other field' 'other field'
table is empty
I have tried this
INSERT INTO table_1 (id,content) VALUES (SELECT id,content FROM table_2)
But this not works
For example :
TABLE_1
'id' 'content'
1 content1
2 content2
3 content3
4 content4
TABLE_2
table is empty
I have tried this
But this not works
16 years 2 months ago #39376
by xillibit
In this point, you need a php script to do that, i don't know if you have php skills. You need to do something like that :
This is just an example and it's not complete
$my_datas = "SELECT id,content FROM table_2";
//if you using the joomla! framework you a $mydatabase->loadObjectList ()
foreach ($my_datas as $row) {
INSERT INTO table_1 (id,content) VALUES ($row->id,$row->content)
16 years 2 months ago #39377
by dany31
ok thank you very much, I will try this method !
Hard job but very interesting..
Time to create page: 0.369 seconds
