Question Vbulletin to Kunena, jos_fb_messages
16 years 2 months ago #39230 by dany31
Hi :)
Sorry for my english, i'm french.
I'm migrating VBulletin to Kunena.
In VB, in "post" table, i have this fields
postid threadid parentid
in Kunena
id parent thread catid
What is exactly the correspondance ?
ok postid --> id
threadid --> thread ?
parentid --> ??????
Thanks for your support,
Dany
16 years 2 months ago #39252 by Matias
postid => id
parentid => parent
threadid => thread
catid can be found in another table (threads(?) table, most likely threadid(?))
16 years 2 months ago - 16 years 2 months ago #39324 by dany31
thanks Matias :)
have you already migrate vbulletin to kunena ?
I have few problem with post migration :(
I can migrate posts, but next,I think there are a problem with id, thread or parent.. When I click on post (right panel, last post etc..) Kunena do not link to post id but to post thread.
For example, if
post id = 20000
parent = 19850
thread = 8600
Kunena try to search post #8600
But in jos_fb_messages table, id parent and thread are corrects (copied from postid, parentid and threadid from vbulletin)
Last edit: 16 years 2 months ago by dany31. Reason: age
16 years 2 months ago #39333 by Matias
I'm not familiar with VB; I haven't even used it much.
And yes, Kunena does just like that. You need to fetch first message of that thread and that will be your threadid in kunena.
16 years 2 months ago #39334 by dany31
hmm ok..
and thread = parent in Kunena ?
16 years 2 months ago #39337 by Matias
No. Parent looks the same as in VB. It's the post you answered to (reply/quote).
So to map thread from VB to Kunena, you need to look at the threads table and to find first message. That first message = thread in Kunena.
Time to create page: 0.204 seconds
