Question 1.5.9 - Known issues
16 years 9 months ago - 16 years 9 months ago #38497
1.5.9 - Known issues was created by sozzled
Here is the list of issues and/or problems that I have discovered with K 1.5.9. This list is not 100% complete and it's not an official list, either:
Quote button to reply to a post truncates the subject if the subject contains quotation marks
Built-in avatars do not display
Community Builder avatars are too large for the display
As far as I can tell, the dozens of other reported "problems" have all resulted from peculiar instances of web hosting policies, conflicts with other Joomla extensions, requests for new features that have not been implemented or users' unfamiliarity with (or misuse of) Kunena's control mechanisms.
- The old Fireboard-style templates are installed when users upgrade from K 1.5.7 or earlier.
- See discussion There is only one endorsed and supported Kunena template
- The old templates (default_gray, default_green, default_red) will be *removed* in K1.6.
- Search queries containing quoted strings are truncated
- This issue has not been resolved.
- See discussion K 1.5.8: Using Quote"button" truncates Subject
- This matter has been addressed in K 1.6.
- See discussion Avatar not display in Kunena 1.5.9
- There is a workaround for this issue.
- See discussion Problem with Kunena 1.5.8 + CB Avatar
- There is a simple workaround for this.
Last edit: 16 years 9 months ago by sozzled.
The topic has been locked.
16 years 9 months ago - 16 years 9 months ago #39804
Replied by sozzled on topic Re:1.5.9 - Known Issues: Search function does not return results if you use + - ' or " characters
There is a known issue with the Kunena search function.
Searches containing the following characters will not return any results:
16 years 9 months ago #39905
Replied by sozzled on topic Re:1.5.9 - Known Issues: Topic icon reset during edit
If you post a new topic in a discussion and assign a topic icon to it but later edit that message, unless you reassign the topic icon, the topic icon will be "lost" when it is resubmitted to the forum. This is a known behaviour in K 1.5.x that will be addressed in K 1.6.
