Question Errors: Constant_KUNENA etc etc
16 years 10 months ago - 16 years 10 months ago #37723 by MartinD
The above list of errors is only a short one - the actual list is huge!
Hi - What do you mean?
I have attached both my language files from administrator/components/com_kunena/language
File Attachment:
File Name: kunena-20100121.zip
File Size:65.27 KB
Last edit: 16 years 10 months ago by MartinD.
16 years 10 months ago #37730 by xillibit
I looked your files, they are corrects, so i don't know where is the source of the problem, no others components can be used these constants...
16 years 10 months ago - 16 years 10 months ago #37731 by MartinD
I sent you a PM..
Can not understand why you dont see the errors on the forum index page..
See attached for list of errors...
File Attachment:
File Name: error-20100121.zip
File Size:14.08 KB
16 years 10 months ago #37755 by sozzled
MartinD wrote:
Upgraded to the latest Kunena - 1.5.8 ... Using Default template
Which Kunena template are you using? The default template or the default_ex template?
16 years 10 months ago - 16 years 10 months ago #37845 by MartinD
I was using Default_Red
I'm now using Default_ex - All is fine on both languages..
I just read this thread here
if Default_Red is not supported and not updated for the current release of Kunena why are they in the folder?
16 years 10 months ago #37851 by xillibit
Because this haven't be changed from the fireboard days, if you upgrade to Kunena 1.6.0 from kunena 1.5.8, all deprecated templates will removed from filesystem.
