Question Errors: Constant_KUNENA etc etc
Upgraded to the latest Kunena - 1.5.8
I'm using 2 language - English - German - for English I followed a thread on the forums here - but I'm still getting scrolling errors with the German language - I have also updated the latest German language files..
Using Default template
Shows only on the forum Index page
Below is only a small snip of the errors - the list is x10 longer..
Any ideas?
Also getting a Jave error on the forums:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729)
Timestamp: Thu, 21 Jan 2010 09:34:55 UTC
Message: 'jQuery.fn.qtip.styles' is null or not an object
Line: 1
Char: 19310
Code: 0
URI: www.skaten-paderborn.de/components/com_c...s/script-1.2.pack.js
Try to re-uplaod your language file, check if you have some conflicting plugins : docs.kunena.com/index.php/Conflicting_plugins
But i think that you a javascript conflict with jomsocial.
I have re uploaded both the german Language file and the English file but still the same..
I have also disabled any conflicting plugins..
