Kunena 7.0.8 Released
Question Convert SMF 1.1.10 to Kunena 1.5.6
16 years 9 months ago - 16 years 9 months ago #32396 by ormuz
it works! thanks a lot
But i'm losing 2000 messages, the script give me this error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
Any idea?
Last edit: 16 years 9 months ago by ormuz.
16 years 9 months ago #32397 by mythus
Greetings,
You need to open up your .sql file containing your messages and search for all '' entries and remove em. For somereason it hates those because it interputs those as code or whatnot. For example, my site is Legends of Nor'Ova. Well I had to go in and remove all ' in the database to make it read NorOva instead.
Once doing that, try again and it should work. It's a pain, but hey... at least there's a way to convert :).
16 years 9 months ago #32398 by ormuz
mythus wrote:
Greetings,
The only " I have is in all the others sql files too, smf_users, smf_categories ...etc
Is this
SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
I think I can't remove that...
16 years 9 months ago #32401 by mythus
No, you can't remove that.
I am willing to be it is finding a '' in smf_messages. Probably a ' that got changed into '' by the wonderful database demons.
16 years 9 months ago #32531 by StAlex
ormuz wrote:
Any idea?
Please, send a full stdout of script. May be it contain full SQL-instruction. It can help to find solution for you.
16 years 8 months ago #32871 by admiral_trigger_happy
I tried to do a conversion and got a similar problem
The export is putting '' (two separate inverted commas) where it finds a ' in the body text when I exported my tables too.
I'm did a find replace for '', to qqw, then I did a find replace '' to \' and I did a find replace for qqw, back to '',
(I'm pretty sure the '', is supposed to be like that thats why I changed them to something else then back)
Hopefully this will fix it, I'll report back
