Question All post counts now at zero after migration
17 years 1 month ago - 17 years 1 month ago #30233 by Matias
mtwMigrator seems to break FireBoard and Kunena installation in a way or another. It's more reliable just to copy all the tables to new site (+ change table collation to UTF-8) and install Kunena.
I just spend some time figuring out how to recalculate user post counts:
INSERT INTO jos_fb_users (userid, posts) SELECT userid, COUNT(userid) FROM jos_fb_messages WHERE userid>0 AND hold=0 GROUP BY userid ON DUPLICATE KEY UPDATE posts=VALUES(posts)
I will try to do the same for categories soon..
Last edit: 17 years 1 month ago by Matias.
17 years 1 month ago - 17 years 1 month ago #30236 by Matias
This category count update will work only IF YOU DO NOT HAVE subcategories:
INSERT INTO jos_fb_categories (id, numTopics, numPosts) SELECT m.catid, SUM( m.parent=0 ), SUM( m.parent>0 ) FROM jos_fb_messages as m LEFT JOIN jos_fb_categories AS c ON c.id=m.catid WHERE m.catid >0 AND m.hold=0 GROUP BY catid ON DUPLICATE KEY UPDATE numTopics=VALUES(numTopics), numPosts=VALUES(numPosts); INSERT INTO jos_fb_categories (id, numTopics, numPosts) SELECT parent, SUM( numTopics ), SUM( numPosts ) FROM jos_fb_categories WHERE parent > 0 GROUP BY parent ON DUPLICATE KEY UPDATE numTopics=VALUES(numTopics), numPosts=VALUES(numPosts);
If you do have subcategories, the second query is not enough and you need some php magic to sum subcategories and category together to get the right number.. Or you can do it manually in phpmyadmin.
