Question no barcode, no smiles
- knight_diver
16 years 9 months ago #24763
by knight_diver
no barcode, no smiles was created by knight_diver
I have kunena 1.5.4 running on joomla 1.5.11 and everything seams to be ok, but neither smilies nnor boardcode buttons are working. check circles under topic icons are missing.
16 years 9 months ago #24765
by Lintzy
Replied by Lintzy on topic Re:no barcode, no smiles
Do you have installed another language than english in Kunena?
- knight_diver
16 years 9 months ago #24767
by knight_diver
Replied by knight_diver on topic Re:no barcode, no smiles
yes, russian. and it was done in a rather barbaric way (just replaced the lang files). but still i had the module deleted and installed again in english. no change.
16 years 9 months ago #24769
by xillibit
Replied by xillibit on topic Re:no barcode, no smiles
Check that you have the smilies in components\com_kunena\template\default_ex\images\english\emoticons.
16 years 9 months ago - 16 years 9 months ago #24770
by Lintzy
which module did you delete? There is no existing module in Kunena itself. Kunena is a component.
Ok, to install another language only add the language file into the folder with the english language file.
the folder = administrator/components/com_kunena/language
here you should have kunena.english.php and kunena.russian.php (or how your language file is named, I don't know exactly).
Additional to the language file you must install a folder russian into
components/com_kunena/template/default_ex/images
You should have in folder images two subfolders: english and russian.
Of course the folder russian should contain same folderstructure and content like the folder english (emoticons, graph, icons, ranks PLUS the images themselves).
If you don't have russian buttons, you can help yourself so: Copy the folder english and name it russian.
Last edit: 16 years 9 months ago by Lintzy.
- knight_diver
16 years 9 months ago #24771
by knight_diver
ok. first thing is to a clean uninstall. because just deleting and installing the component do not fix anything. how do I do that?
a little offtop, but i still have a problem of missing checkboxes and their circle equivalents and it's a global problem. does anyone know what night have caused that?
