Question Installation Problem
17 years 4 months ago #23333 by topmaniac
Hello everybody!
I have a problem
i cant install kunena 5.4 ...
i have execution time of 30sec.... in phpini...
joomla = noftp...
uplaoded to the temp folder and manual install ... but same...
connection refused... "white page"...
17 years 4 months ago #23334 by xillibit
Replied by xillibit on topic Re:Installation Problem
I hope that you already read this doc which can be useful for you : docs.kunena.com/index.php/Installation_Issues
A white page mean that you have a php error, enable the debug mode in the joomla configuration panel.
17 years 4 months ago - 17 years 4 months ago #23336 by topmaniac
Replied by topmaniac on topic Re:Installation Problem
Your joomla /administrator/components and /components directories may not be writable
yes it is writeable!!!
Fatal error Maximum execution time of 30 seconds exceeded
time = 120 seconds
Your php.ini
maximum upload
timeout may be less than 30 seconds, too short a time for the upload to complete
Your tmp directory setting in Joomla's Configuration.php may be invalid, or the directory may not be writable
maximum upload 150MB
larger than 30seconds
tmp directory aviable and writeable
joomla complete fresh install 1.5.12
everything is writeable ...
php.ini works fine...
install package uplaoded to the tmp folder ... extracted... install from a folder...
and normal install ....
both same the same ... no install ...
not really a white page ... everything workxx after 10minutes load ... the page change ... (connection refused) internet explorer 8 message
Last edit: 17 years 4 months ago by topmaniac.
17 years 4 months ago - 17 years 4 months ago #23338 by sozzled
G'day, topmaniac, I'm sorry to hear you're having problems with your K 1.5.4 installation. This is a long-shot suggestion (it may not work) and it's not covered in the "installation issues" article that xillibit mentions, but you might like to read docs.joomla.org/What_are_the_recommended...ctory_permissions%3F .
If I were in your place I would apply the directory and file permissions, as recommended, across your entire Joomla website and then try the installation procedure again. Good luck. Please keep us informed.
Last edit: 17 years 4 months ago by sozzled.
17 years 4 months ago #23341 by topmaniac
link doesnt work
17 years 4 months ago - 17 years 4 months ago #23343 by sozzled
I'm sorry ... there was an extra period added to the end of the url which should have been docs.joomla.org/What_are_the_recommended...ctory_permissions%3F .
Time to create page: 0.152 seconds
