Important 2 errors in Kunena
16 years 5 months ago #50067 by sozzled
Replied by sozzled on topic Re: 2 errors in Kunena
I have no idea what this "grey" Kunena template is, who designed it, or what version of Kunena it was created for. I am pleased that you have upgraded to K 1.5.11. Your pagination issue and user preference issue will disappear if you use the default_ex template. What have you got to lose? :)
16 years 5 months ago #50068 by mitchmink
Replied by mitchmink on topic Re: 2 errors in Kunena
it is not a good template for my site haha :) the style is not good enough
16 years 5 months ago #50072 by Cerberus
Replied by Cerberus on topic Re: 2 errors in Kunena
Then use firebug fro firefox and modify the COLORS of the default template to match your site :) as long as you use the file from K1.5.11 and your sensible with what you change there should not be to many issues.
16 years 5 months ago #50074 by Ganzuelo
Replied by Ganzuelo on topic Re: 2 errors in Kunena
The current templates have the code built into it Mitch, so if you upgrade to the latest build of Kunena but still use that older template you are pretty much still using a older version of Kunena.
I would recommend using the default_ex and do what Cerb said and modify the default_ex template.
16 years 4 months ago #53207 by F0l2saken
Replied by F0l2saken on topic Re: 2 errors in Kunena
Please stop blaming people for using custom templates, I've seen several posts all over the place about this problem with the forums and it HAS NOTHING to do with the template. I'm using your forums with a fresh install of Kuena with the templates you include with it, and I have the same problem exactly.
The problem is with the forums, it's a bug, and all anyone ever says from here is that it's the templates fault. Not true at all. This problem will never get fixed if all that happens is the blame is passed onto the user for trying to modify the template.
16 years 4 months ago - 16 years 4 months ago #53215 by Cerberus
F0l2saken wrote: Please stop blaming people for using custom templates, I've seen several posts all over the place about this problem with the forums and it HAS NOTHING to do with the template. I'm using your forums with a fresh install of Kuena with the templates you include with it, and I have the same problem exactly.
i am personaly a template builder and i do not have this error in ANY of my templates so please state the answers to a few question below so i can see what exactly your issue is as " i have the same issue " is about as useful to me as a chocolate teapot.
kunena version ?
joomla version ?
templates being used ??
any other special mod or plugin loaded to your site ???
i am not affliated with kunena in any way other than i run a gaming site that uses kunena..
Last edit: 16 years 4 months ago by Cerberus.
