Question [Topic closed by moderator - assumed resolved] Joomla SEO issues: Kunena forum pages do not display
16 years 1 month ago #44144 by @quila
Replied by @quila on topic Re:lack of display
If your forum now appaers correctly try to enable only first option (Search Engine Friendly URLs) in the Joomla SEO configuration.
16 years 1 month ago #44151 by chicaloca
Replied by chicaloca on topic Re:lack of display
thats the one i changed and it works now...
what would i need to change to get rid of the log in request? im sure ill get the hang of it all eventually.....
16 years 1 month ago #44188 by sozzled
Search engine optimization (SEO) can be a quite mysterious to new users of Joomla. Knowing how to implement the Joomla SEO features is actually something I would recommend to all users (not just those who use Kunena). But, once you've learned how to do it, it's a skill that will last a lifetime ... or for at least as long as we're using Joomla 1.5 and the world wide web! B)
There are a couple of things you need to make sure you setup properly: the Joola Global Configuration is only one area of changes that you need to make. You also need to have a webserver (like Apache) that supports SEO. And you probably need to have a webserver configuration file (like .htaccess) to handle the incoming HTTP requests.
What has all of this got to do with Kunena. Everything! Kunena uses whatever Joomla SEO you have installed. You can use third-party SEO tools (like sh404SEF) but, from what limited evidence I've seen, these may cause more harm than good.
16 years 1 month ago #44195 by @quila
Can you explain better what login request you want to get rid? I don't understand what you mean.
16 years 1 month ago - 16 years 1 month ago #44225 by bigmike0601
i can't enable SEF Urls either. I see that the htaccess file needs to be renamed for apache users. How is this done?
Last edit: 16 years 1 month ago by sozzled. Reason: Changed subject to improve search relevance
16 years 1 month ago - 16 years 1 month ago #44226 by Cerberus
FTP in to your websites shell and then you can change name of .htaccess file :)
Time to create page: 0.295 seconds
