Question Removal of Smite?
16 years 10 months ago #37981 by sozzled
Replied by sozzled on topic Re:Removal of Smite?
OurIslamic wrote:
How do I have ONLY thumbs up enabled though?
I understand perfectly the question. If you want to tinker with the Kunena code, you're welcome to do it. That's your problem. If, by tinkering with the Kunena code, you make it impossible later on to upgrade Kunena, that is also your problem. There is no "disable just the thumbs down" option. You can enable "thumbs up and down" or disable them both. Those are your choices at the moment. I've given you my suggestion; you are welcome to wait for someone else to come along later with another idea. B)
16 years 10 months ago #37982 by OurIslamic
Replied by OurIslamic on topic Re:Removal of Smite?
All right, thanks :).
