Question Removal of Smite?
16 years 10 months ago #37684 by OurIslamic
Removal of Smite? was created by OurIslamic
How can I remove "smite" for Karma?
16 years 10 months ago - 16 years 10 months ago #37687 by sozzled
Replied by sozzled on topic Re:Removal of Smite?
The easiest way to do this is to disable the Kunena karma subsystem. It's precisely because people abuse the smite function that serious forum administrators don't even bother offering a "karma" rewards system at all. See Kunena Karma and Unanswered Thread as just one example where we've discussed the virtues vs. the dangers of karma.
Disable karma: problem solved. B)
Last edit: 16 years 10 months ago by sozzled.
16 years 10 months ago #37801 by linknode
Replied by linknode on topic Re:Removal of Smite?
The question is not how do I remove but how do I enable thumbs up and thumbs down?
16 years 10 months ago - 16 years 10 months ago #37802 by sozzled
Go to the Kunena Backend: Select Kunena Configuration » Frontend » User Related » Show Karma Indicator = Yes
I still think that enabling karma (or "thumbs up/down" or whatever you like to call it) is a bad idea.
16 years 10 months ago #37804 by linknode
Thanks for the help, can't believe I missed that.
16 years 10 months ago #37976 by OurIslamic
Replied by OurIslamic on topic Re:Removal of Smite?
How do I have ONLY thumbs up enabled though?
