Question JS error when using BBcode
I get JS error when I use BBcode on my page. For the moment I just use i locally so I have nothing to show up.
Anyway I used version 1.5.6 when I did a clean install.
It didn't work to use BBcode. I got the following error, I use firebug to get to know the problem:
syntax error
[Break on this error] color = String(numberList[r]) + Stri...rList[g]) + String(numberList<strong>);\n
Then I uninstalled it and used Kunena 1.5.7 but even though I get the same problem.
When I use any BBcode the BBcode doesn't show up in the textarea.
What could I do to fix this problem?
/Thanks for helping me..
If BBCode works for you in this forum, there is most likely some kind of conflict between Kunena and some module or Joomla template you have installed.
If we find out what causes this error, it can be fixed. So first I would like you to switch using default templates in both Joomla and Kunena to see if that is the problem. If it does not help, try disabling modules to see, if it is some of them.
i tried to use the default joomla theme but even though it doesnt work for me..
yes i can use bbcode in this kunena forum.. but i cannot get it work for me.
/bes regards
i know what the problem is..
i did a pure clean installation of joomla standard without any templates.
then i installed kunena.. it worked like a charm..
in my other installation i have the rockettheme affinity template installed.. it seems to be conflicting with thair template.
how can we solve this?
Already your first message reveals me something, so maybe we can get this solved this time!
It seems that the first conflict is "color".
Edit components/com_kunena/lib/kunena.bbcode.js.php and replace variable color with kcolor in lines: 86, 99, 100, 115, 116, 117. Do not touch anything else. Did it help at all?
i still get this error:
thanks for your help
