Question JS error when using BBcode
16 years 11 months ago #33462 by zilveer
matias:
could you please help me with this issue.
i can give you whatever information you need.
/regards
16 years 11 months ago #33652 by Matias
I do not know why you will get syntax error. Maybe you could PM me URL/login info?
16 years 11 months ago - 16 years 11 months ago #33664 by Creatorffm
Hi all give this a try: RokCandy Fix . Hope this helps. It worked for me and I am also using the Affinity template. You don not need to worry about the RokBox fix in the same post. Just look for the BBcode line in the rokcandy_system.php and place the suggested code below it. The fix is the last post in the topic. Hope this helps.
Cheers
Dave
Dave "Creator" Marshall
Last edit: 16 years 11 months ago by Creatorffm.
16 years 11 months ago #33748 by zilveer
thanks for the help matias and creatorffm.
i tried to disable system - rokcandy in the plugins and it worked like a charm.
it seems to be the rokcandy macros which is the problem.
note. i didnt want to change anything in the files sine when updating kunena later i dont want to make changes at every update.
thanks once again:)
