Question Forums do not display
17 years 3 months ago #25879 by thomaz
Replied by thomaz on topic Re:Forums do not display
sorry.. this site is being tested on my intranet right now...
Can I post the config list here? and take a snap shot of what I'm seeing on the forum?
I've tried everything - this is really strange... there must be some stupid conflict somewhere causing it...
thnx
17 years 3 months ago #25914 by sozzled
Replied by sozzled on topic Re:Forums do not display
G'day, Thomas. I really sympathise with your difficult situation.
I'm sorry to say, posting images of all the components, modules, plugins, Kunena configuration settings and forum settings (which is probably what's indicated) will take you ages to do and us even longer to decipher. So, here's a few tips:
99% of problems in these cases are caused by users changing the original settings. Yes, that may sound harsh criticism, but that's typically what happens. In the other 1% of cases the problem lies in the webhosting service or the component software failing to meet certain minimum technical requirements. If you read the technical requirements section of the Wiki guide, it specifies - wait for it - the technical requirements (surprise, surprise).
In your situation it may ultimately be that your intranet service doesn't meet the technical requirements and that Kunena is not feasible ... and that's not your fault. Que sera sera! :( But perhaps the first step is to ascertain whether your intranet service qualifies to host Kunena.
This is my suggestion:
  1. Create a completely new Joomla 1.5.14 installation. Make no changes to it whatsoever.
  2. Install Kunena 1.5.4. Make no changes to it whatsover.
  3. Test that you can use Kunena on your Joomla installation. If it works then you know that it's something else that you have done on the site you are currently trying to build.
Let's establish a basis on which we can move forward.
