Question Forums do not display
17 years 3 months ago #25630 by thomaz
Forums do not display was created by thomaz
Just installed Kunena.
(Joomla 1.5.14 and Jomsocial)
Created two new categories and six forums, three under each category.
When I created a new category I selected form the pulldown "No Parent"
In the notes you state "To create a category, choose 'Top Level Category' as a parent."
but this choice is not available only "No Parent"
I've used Fireboard before with no problems.. am I missing something? :(
I have tried every combination in the config from changing the template to "Use Joomla Style?" and still no forums show up. :huh:
thanks
-thomas
17 years 3 months ago #25755 by @quila
Replied by @quila on topic Re:Forums do not display
Hi thomaz,
here is useful documentation for creating forum and category docs.kunena.com/index.php/How_to_create_...Forums_and_Subforums
and be sure to publish all forums.
Regards
17 years 3 months ago #25836 by thomaz
Replied by thomaz on topic Re:Forums do not display
I know how to setup categories and forums. It's the same as Fireboard which I used to use. I don't want to use Fireboard because I do not want to run in Joomla Legacy mode.
Anyway, just to make sure nothing was changed I checked out the "How to create Categories, Forums and Subforums" of Kunena Docs. And I'm doing exactly that.
still no Categories show and no forums and there is not a "New Thread" link anywhere to be found.
I've setup Jomsocial integration in the Configuration section of Kunena - would this cause a problem?
I'm also using the mynxx Rocket template as well -- problems there?
I've also re-installed Kunena twice.
any ideas?
17 years 3 months ago #25838 by sozzled
Replied by sozzled on topic Re:Forums do not display
Make sure you are not using the dreaded RokCandy plugin. Do you have any problems when you use a "standard" Joomla theme like rhuk_milkyway? Have you searched the forum for other explanations about why your "forums do not display"? Other than these things, and possibly providing us with a link to your website which might help us to help you, make sure you've published your forum categories as @quila reminded you to do.
17 years 3 months ago #25839 by thomaz
no rockcandy being used.
and I have tried multiple templates and still nothing.
the page shows up just no categories or forums are listed and I have 6 forums all published. ;-)
17 years 3 months ago #25840 by sozzled
I'm prepared to have a look at your configuration for you, if you would like. Please PM me with your site address and administration user account information.
