Question Direct (Auto) Quick Reply?
17 years 2 months ago - 17 years 2 months ago #25858 by guerilla
Replied by guerilla on topic Re: Direct Quick Reply?
you must move quck reply area to viewp.php. open message.php in default_ex folder and delete this part:
<?php if (!isset($msg_closed)) { ?> <div id = "sc<?php echo $msg_id; ?>" class = "switchcontent"> <!-- make this div distinct from others on this page --> <?php //see if we need the users realname or his loginname if ($fbConfig->username) { $authorName = $kunena_my->username; } else { $authorName = $user->name; } //contruct the reply subject $resubject = kunena_htmlspecialchars(strtolower(substr($msg_subject, 0, strlen(_POST_RE))) == strtolower(_POST_RE) ? $msg_subject : _POST_RE .' '. $msg_subject); ?> <form action = "<?php echo JRoute::_(KUNENA_LIVEURLREL. '&amp;func=post'); ?>" method = "post" name = "postform" enctype = "multipart/form-data"> <input type = "hidden" name = "parentid" value = "<?php echo $msg_id;?>"/> <input type = "hidden" name = "catid" value = "<?php echo $catid;?>"/> <input type = "hidden" name = "action" value = "post"/> <input type = "hidden" name = "contentURL" value = "empty"/> <input type = "text" name = "subject" size = "35" class = "inputbox" maxlength = "<?php echo $fbConfig->maxsubject;?>" value = "<?php echo $resubject;?>"/> <textarea class = "inputbox" name = "message" rows = "6" cols = "60" style = "height: 100px; width: 100%; overflow:auto;"></textarea> <?php // Begin captcha . Thanks Adeptus if ($fbConfig->captcha && $kunena_my->id < 1) { ?> <?php echo _KUNENA_CAPDESC.'&nbsp;'?> <input name="txtNumber" type="text" id="txtNumber" value="" style="vertical-align:middle" size="10">&nbsp; <img src="index2.php?option=com_kunena&func=showcaptcha" alt="" /><br /> <?php } // Finish captcha ?> <input type = "submit" class = "fb_button fb_qr_fire" name = "submit" value = "<?php @print(_GEN_CONTINUE);?>"/> <input type = "button" class = "fb_button fb_qm_cncl_btn" id = "cancel__<?php echo $msg_id; ?>" name = "cancel" value = "<?php @print(_KUNENA_CANCEL);?>"/> <small><em><?php echo _KUNENA_QMESSAGE_NOTE?></em></small> </form> </div> <?php } ?>
and this:
<?php echo isset($fbIcons['quickmsg']) ? '<img src="' . KUNENA_URLICONSPATH . $fbIcons['quickmsg'] . '" border="0" alt="' . _KUNENA_QUICKMSG . '" />' . '' : ' <img src="' . KUNENA_URLEMOTIONSPATH . 'quickmsg.gif" border="0" alt="' . _KUNENA_QUICKMSG . '" />'; ?>
then open view.php and find this:
<!-- B: List Actions Bottom -->
and paste this code below:
<?php if (!isset($msg_closed)) { ?> <table class = "fb_blocktable<?php echo $objCatInfo->class_sfx; ?>" id="fb_views" cellpadding = "0" cellspacing = "0" border = "0" width = "100%"> <thead> <tr> <th align="left"> <div class = "fb_title_cover fbm"> <span class = "fb_title fbl"><b><?php echo _KUNENA_QUICKMSG; ?></b></span> </div> <!-- make this div distinct from others on this page --> <?php //see if we need the users realname or his loginname if ($fbConfig->username) { $authorName = $kunena_my->username; } else { $authorName = $user->name; } //contruct the reply subject $resubject = kunena_htmlspecialchars(strtolower(substr($fb_subject_txt, 0, strlen(_POST_RE))) == strtolower(_POST_RE) ? $fb_subject_txt : _POST_RE .' '. $fb_subject_txt); ?></th></tr><tr><td class = "fb-msgview-right"> <form action = "<?php echo JRoute::_(KUNENA_LIVEURLREL. '&amp;func=post'); ?>" method = "post" name = "postform" enctype = "multipart/form-data"> <input type = "hidden" name = "parentid" value = "<?php echo $msg_id;?>"/> <input type = "hidden" name = "catid" value = "<?php echo $catid;?>"/> <input type = "hidden" name = "action" value = "post"/> <input type = "hidden" name = "contentURL" value = "empty"/> <input type = "text" name = "subject" size = "35" class = "inputbox" maxlength = "<?php echo $fbConfig->maxsubject;?>" value = "<?php echo $resubject;?>"/> <textarea class = "inputbox" name = "message" rows = "6" cols = "60" style = "height: 100px; width: 100%; overflow:auto;"></textarea> <?php // Begin captcha . Thanks Adeptus if ($fbConfig->captcha && $kunena_my->id < 1) { ?> <?php echo _KUNENA_CAPDESC.'&nbsp;'?> <input name="txtNumber" type="text" id="txtNumber" value="" style="vertical-align:middle" size="10">&nbsp; <img src="index2.php?option=com_kunena&func=showcaptcha" alt="" /><br /> <?php } // Finish captcha ?> <input type = "submit" class = "fb_button fb_qr_fire" name = "submit" value = "<?php @print(_GEN_CONTINUE);?>"/> <input type = "button" class = "fb_button fb_qm_cncl_btn" id = "cancel__<?php echo $msg_id; ?>" name = "cancel" value = "<?php @print(_KUNENA_CANCEL);?>"/> <small><em><?php echo _KUNENA_QMESSAGE_NOTE?></em></small> </form> </div> <?php } ?></td></tr></table>
finally find this code
unset( $msg_id,
and change to this:
unset( //$msg_id,
Last edit: 17 years 2 months ago by guerilla.
17 years 2 months ago - 17 years 2 months ago #25992 by RonanK
Replied by RonanK on topic Re: Direct Quick Reply?
Guerilla, thank you very much. This works perfectly. I have a little question about it: Can we make it invisible for non-registered visitors?
Last edit: 17 years 2 months ago by RonanK.
17 years 2 months ago #25999 by guerilla
sure. in the code i've gave, just change this part:
to this:
if ($kunena_my->id > 0 && !isset($msg_closed))
17 years 2 months ago #26001 by RonanK
You really helped me. I'm sure a lot of Kunena users who are looking for Phpbb style quick reply will use this information. Thanks again.
17 years 2 months ago #26019 by guerilla
17 years 2 months ago - 17 years 2 months ago #26169 by sozzled
I've been thinking about the value of this hack and I've decided that I was probably wrong with my initial reaction to the idea. Instead I have decided to incorporate the "always available" quick reply feature into a phpBB-like Kunena template.
:) Thanks, guerilla, for your contribution. I've made a small improvement (I think) to your idea ( #25999 )
Instead of changing
to
I've used instead:
if (($kunena_my->id > 0 && !isset($msg_closed)) || $fbConfig->pubwrite)
This allows for the possibility that the forum is setup for public write access.
Last edit: 17 years 2 months ago by sozzled.
