Question Direct (Auto) Quick Reply?
16 years 4 months ago #51397 by Clutch34
Replied by Clutch34 on topic Re: Direct Quick Reply?
So I wanted to try this on my Kunena website as well but I received this error message:
Parse error: syntax error, unexpected '?' in /home/xxxxxx/public_html/components/com_kunena/template/default_ex/view.php on line 1233
Line 1233 says this:
<table class = "fb_blocktable<?php echo $objCatInfo->class_sfx; ? >" id="fb_views" cellpadding = "0" cellspacing = "0" border = "0" width = "100%">
Any help on how to fix this?
Thanks!
16 years 4 months ago #51404 by guerilla
Replied by guerilla on topic Re: Direct Quick Reply?
delete space between theese two character: ? >
it must be like this: ?>
15 years 9 months ago #83313 by andreicukapp
how can I do this in kunena 1.6.1 or 1.6.2?
I cannot find those codes..
15 years 9 months ago - 15 years 9 months ago #83326 by ChaosHead
Kunena 1.6.0 - 1.6.2
in file: view.php
after this line
<?php $this->displayThreadActions(1); ?>
(Such lines in a code two. After that that in the end.)
Add:
<?php if ((CKunenaTools::isModerator ( $this->my->id, $this->catid ) || !$this->topicLocked)&&$this->my->id) :?> <div id="kreply<?php echo intval($this->id)?>_form" class="kreply-form"> <form action="<?php echo CKunenaLink::GetPostURL(); ?>" method="post" name="postform" enctype="multipart/form-data"> <input type="hidden" name="parentid" value="<?php echo intval($this->id)?>" /> <input type="hidden" name="catid" value="<?php echo intval($this->catid)?>" /> <input type="hidden" name="action" value="post" /> <?php echo JHTML::_( 'form.token' )?> <?php if ($this->allow_anonymous): ?> <input type="text" name="authorname" size="35" class="kinputbox postinput" maxlength="35" value="<?php echo $this->escape($this->myname)?>" /><br /> <input type="checkbox" id="kanonymous<?php echo intval($this->id)?>" name="anonymous" value="1" class="kinputbox postinput" <?php if ($this->anonymous) echo 'checked="checked"'; ?> /> <label for="kanonymous<?php echo intval($this->id)?>"><?php echo JText::_('COM_KUNENA_POST_AS_ANONYMOUS_DESC')?></label><br /> <?php else: ?> <input type="hidden" name="authorname" value="<?php echo $this->escape($this->myname)?>" /> <?php endif; ?> <textarea class="inputbox" name="message" rows="6" cols="60"></textarea><br /> <input type="submit" class="kbutton kreply-submit" name="submit" value="<?php echo JText::_('COM_KUNENA_GEN_CONTINUE')?>" title="<?php echo (JText::_('COM_KUNENA_EDITOR_HELPLINE_SUBMIT'));?>" /> <small><?php echo JText::_('COM_KUNENA_QMESSAGE_NOTE')?></small> </form> </div> <?php endif ?>
If want to remove all other fast reply buttons after each post: in a file message.actions.php delete a line:
<?php echo $this->message_quickreply; ?>
Screenshot:
Last edit: 15 years 9 months ago by ChaosHead.
