Question Copy entire forum content from one site to another
I don't know, but by upgrading to the latest version it could solve the issue.If I disable the ftp in joomla, won't that create problems with articles?
YorkshireLions wrote:
FYI : The version 1.5.4 of kunena that you are using contains a security issue which could be used to do sql injection. The kunena version is displayed in credits page, so it's easy to nobody to know the issue which have this version and maybe break your site. In K1.5.11, there are plenty of bugs solved maybe more than 50, i don't know exactly the number.I'm very reluctant to upgrade Kunena because in my previous experiences with upgrading mac software, it creates more problems than it solves.
- YorkshireLions
- Junior Member
- Thank you received: 1
I changed the config file in joomla to make sure it was writeable and disabled ftp in config.
Got a better response but I'm not over keen about disabling ftp as a work around. When I tried uploading an avatar again, I got this error message.
It still works, just don't want my users getting the wrong idea.
Cheers.
Check too the access right : help.ubuntu.com/community/Joomla#Configure%20Access%20Rights
- YorkshireLions
- Junior Member
- YorkshireLions
- Junior Member
Gone full circle - disabled ftp and chmod files/folder the site wouldn't upload.
enabled ftp the avatar uploads ok but get the following error.
strangly enough, if I choose a generic avatar from the kunena library such as a flower, etc, it deletes and installs perfectly without any error messages.
- dirkovision
- Senior Member
- Thank you received: 4
All i can say hope it helps.
rgds.
