Important [Merged topic] Kunena RSS feed does not work with Registered Users-only forum
16 years 8 months ago #42617 by sozzled
David_Steadson wrote:
In any case the validation problem seems to have been because I lopped off &lang=en from the URL of the feed. It validates on w3.org with it, but gives the "direct access" error without it, despite both working in my browsers.
I mean this in the nicest possible way but who cares? If your RSS feed validates, good: you can feel comfortable knowing that the W3C says your site honours the W3C conventions for RSS feeds. If your feed does not validate but you can view the feed in your web browser, then does it matter?
Let's get back to the issue. What is your specific problem? Was your specific problem knowing why your RSS feed would not validate? I think we've answered that one. What else would you like to know? :)
16 years 8 months ago #42621 by David_Steadson
Yes, the problem is the feed wasn't working in feed modules, and w3.org said it wasn't valid. I had removed the lang=en variable as when I cut and pasted it some characters were corrupted and I thought it was unneeded, given the feed worked in browsers without it.
Returning the variable allows the feed to pass validation and work in modules fine.
Obviously I should have just tried the original feed URL manually, silly of me not to. Thanks again for your help, confirming it validated for you indicated a probable PEBCAK bug on this end. :blush:
16 years 8 months ago #42625 by sozzled
I have PMed shalija to request an update on his situation in order to finalise this thread.
16 years 8 months ago #43541 by pkpandya
I have upgraded to Kunena 1.5.10 and now downgraded to 1.5.9.
Still I get following error, when clicked RSS button on the Discussion Forum
"error on line 1 at column 6: XML declaration allowed only at the start of the document"
At feeds.feedburner.com I get the following error
"The URL you entered does not appear to be a valid feed. We encountered the following problem: Error on line 1: The processing instruction target matching "[xX][mM][lL]" is not allowed."
I dont understand how to solve it.
Can anyone help please,
Prakash
16 years 8 months ago #43543 by xillibit
Can you give a link to your rss feed like that i check what goes wrong ?
16 years 6 months ago #48058 by Bobi
Replied by Bobi on topic RSS Feeds not working!!
Hello
I've got the newest version of kunena but I can't seem to get RSS feeds working.
I mean they're enabled in my configs and all but it won't update new posts.
aao-daily.eu/index.php?option=com_kunena...unc=fb_rss&no_html=1
As you can see here it's not updating my forum posts.
What can I do to fix this? Please advise , thanks!
