- Thank you received: 7
This is not a support forum for Community Builder or its related products. For Community Builder support you should visit
Joomlapolis
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
1 year 6 months ago #233323
by btc
Replied by btc on topic Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
To explain in more detail.
I can bring up a list of everyone registered on the website, but when I click on any name I get the error.
So, on the live site, which works properly, I go to www.pgweb.uk/people/members to see the list of members and when I click on one I see the details of that member. (You need to be logged in to see the list of members.) On the website with K6.4.2 I get the error when I click on anyone's name or when I try to view my own (admin's) profile.
The topic has been locked.
1 year 6 months ago #233327
by btc
I've created a second copy of the website from a backup made today, installed K6.4.2 on top of K6.3, visited Kunena Dashboard so that the tables are updated and tried to access my own proflle using the main menu item
www.pgweb.uk/pgcdev2/people/my-user-profile
(which uses Community Builder) I get the same error as before. Same if I try to access other users' profiles.
# Function Location
1 () JROOT/components/com_comprofiler/plugin/user/plug_cbforums/models/kunena20.php:808
2 cbforumsModel::getUserPosts() JROOT/components/com_comprofiler/plugin/user/plug_cbforums/cbforums.php:472
3 cbforumsField->getField() JROOT/libraries/CBLib/CB/Legacy/cbFieldHandler.php:101
4 cbFieldHandler->getFieldRow() JROOT/components/com_comprofiler/plugin/user/plug_cbforums/cbforums.php:431
5 cbforumsField->getFieldRow() JROOT/libraries/CBLib/CB/Legacy/cbPluginHandler.php:879
6 cbPluginHandler->call() JROOT/libraries/CBLib/CB/Legacy/cbPluginHandler.php:1075
7 cbPluginHandler->callField() JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:1579
8 cbTabs->_getSingleFieldContent() JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:1494
9 cbTabs->_getFieldsContents() JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:1227
10 cbTabs->_getTabContents() JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:371
11 cbTabs->generateViewTabsContent() JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:443
12 cbTabs->getViewTabs() JROOT/libraries/CBLib/CB/Legacy/CBuser.php:410
13 CBuser->getProfileView() JROOT/components/com_comprofiler/comprofiler.html.php:341
14 HTML_comprofiler::userProfile() JROOT/components/com_comprofiler/comprofiler.php:624
15 userProfile() JROOT/components/com_comprofiler/comprofiler.php:117
16 require_once() JROOT/libraries/src/Dispatcher/LegacyComponentDispatcher.php:71
17 Joomla\CMS\Dispatcher\LegacyComponentDispatcher::Joomla\CMS\Dispatcher\{closure}() JROOT/libraries/src/Dispatcher/LegacyComponentDispatcher.php:73
18 Joomla\CMS\Dispatcher\LegacyComponentDispatcher->dispatch() JROOT/libraries/src/Component/ComponentHelper.php:361
19 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/SiteApplication.php:217
20 Joomla\CMS\Application\SiteApplication->dispatch() JROOT/libraries/src/Application/SiteApplication.php:271
21 Joomla\CMS\Application\SiteApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:304
22 Joomla\CMS\Application\CMSApplication->execute() JROOT/includes/app.php:58
23 require_once() JROOT/index.php:32
However, if I look at my profile using the Kunena menu item www.pgweb.uk/pgcdev2/forum/profile (as opposed to the main website menu) it works.
So it looks like CB doesn't work properly with K6.4.2 (and possibly earlier versions of K6.4, which I skipped).
Two things occur to me:
1. I should try recreating the menu items for my profile and other user profiles that are in the main website menu
2. I should try completely ditching Community Builder, which I installed when first setting up the website, expecting it would be useful - but that hasn't really been the case.
Call Stack0 Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
# Function Location
- Thank you received: 196
1 year 6 months ago #233329
by Pinkeltje
Replied by Pinkeltje on topic Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
If you don't need CB then you should delete it indeed. I've done several tests with K 6.4.2 and CB and still can't reproduce your error BTW.
- Thank you received: 2545
1 year 6 months ago #233331
by rich
Replied by rich on topic Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
You use CommunityBuilder 2.10.0+build.2025.02.10.18.59.11.b0d14120b
(see here)
The current version is CommunityBuilder 2.10.0+build.2025.05.06.16.43.20.9842eb8e2 Please install this version and the error should no longer occur.
1 year 6 months ago #233333
by btc
Thanks rich, that's fixed it. Even though the error was occurring when using a CB menu item, it had to be caused by a change to Kunena.
I have to say though that while that was the worst of the unpleasant surprises when moving from K6.3 to K6.4, it was by no means the only one. A whole lot of Kunena settings weren't carried over and reverted to default, eg having User Name displayed instead of real name, and not hiding email addresses. If that was unavoidable, you should warn people so they know they have to review the settings after moving to K6.4. If it could have been avoided, I think you need to issue a new version that carries over settings properly.
1 year 6 months ago #233353
by rich
The user-defined settings should be applied correctly. I have tested it several times and the settings are retained. I don't know how many users have already upgraded to K6.4.2, but if this error were the rule, I'm sure many users would have already complained here.
Time to create page: 0.154 seconds
