This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Question Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
1 year 6 months ago #233317 by btc
I've updated to K6.3 on my development site and have run into an issue with Community Builder integration when trying to access user profiles in CB.
I get the error message
0 Call to undefined method Kunena\Forum\Libraries\User\KunenaUser::get()
Call Stack#FunctionLocation1()JROOT/components/com_comprofiler/plugin/user/plug_cbforums/models/kunena20.php:8082cbforumsModel::getUserPosts()JROOT/components/com_comprofiler/plugin/user/plug_cbforums/cbforums.php:4723cbforumsField->getField()JROOT/libraries/CBLib/CB/Legacy/cbFieldHandler.php:1014cbFieldHandler->getFieldRow()JROOT/components/com_comprofiler/plugin/user/plug_cbforums/cbforums.php:4315cbforumsField->getFieldRow()JROOT/libraries/CBLib/CB/Legacy/cbPluginHandler.php:8796cbPluginHandler->call()JROOT/libraries/CBLib/CB/Legacy/cbPluginHandler.php:10757cbPluginHandler->callField()JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:15798cbTabs->_getSingleFieldContent()JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:14949cbTabs->_getFieldsContents()JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:122710cbTabs->_getTabContents()JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:37111cbTabs->generateViewTabsContent()JROOT/libraries/CBLib/CB/Legacy/cbTabs.php:44312cbTabs->getViewTabs()JROOT/libraries/CBLib/CB/Legacy/CBuser.php:41013CBuser->getProfileView()JROOT/components/com_comprofiler/comprofiler.html.php:34114HTML_comprofiler::userProfile()JROOT/components/com_comprofiler/comprofiler.php:62415userProfile()JROOT/components/com_comprofiler/comprofiler.php:11716require_once()JROOT/libraries/src/Dispatcher/LegacyComponentDispatcher.php:7117Joomla\CMS\Dispatcher\LegacyComponentDispatcher::Joomla\CMS\Dispatcher\{closure}()JROOT/libraries/src/Dispatcher/LegacyComponentDispatcher.php:7318Joomla\CMS\Dispatcher\LegacyComponentDispatcher->dispatch()JROOT/libraries/src/Component/ComponentHelper.php:36119Joomla\CMS\Component\ComponentHelper::renderComponent()JROOT/libraries/src/Application/SiteApplication.php:21720Joomla\CMS\Application\SiteApplication->dispatch()JROOT/libraries/src/Application/SiteApplication.php:27121Joomla\CMS\Application\SiteApplication->doExecute()JROOT/libraries/src/Application/CMSApplication.php:30422Joomla\CMS\Application\CMSApplication->execute()JROOT/includes/app.php:5823require_once()JROOT/index.php:32
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 4294967296 | Max file upload:
Joomla default template details : cassiopeia_casspgc2 | author: PGC Webmaster | version: 1.0 | creationdate: September 2023
Kunena default template details : NTS KBee | author: Nice Theme Store Team | version: 6.1.3 | creationdate: 2025-03-28
Kunena template params:
Kunena version detailed: Kunena 6.4.2 | 2025-04-22 [ Git Repository ]
Third-party components: CommunityBuilder 2.10.0+build.2025.02.10.18.59.11.b0d14120b
Plugins: Search - Kunena Search 6.0.0 | Content - Kunena Discuss 6.0.5
Modules: Kunena Latest 6.0.7 | Kunena Search 6.0.3
The topic has been locked.
1 year 6 months ago - 1 year 6 months ago #233318 by 9themestore
Hi @bt,
Does this error appear on the default Kunena template? If it only appears on our NTS KBee template, please create a support ticket on our website so we can check and help you solve this issue.
Kind regards,
Last edit: 1 year 6 months ago by 9themestore.
1 year 6 months ago #233319 by btc
Thanks,
Just realised by original message erroneously refers to upgrading the development site to K6.3, I should have said K6.4.2. The live site has K6.3 and works fine.
It happens with Aurelia too, so presumably not a 9themestore issue. But it's not clear whether this is an issue with Kunena or with Community Builder, as it occurs when trying to access a user's profile using what I assume is a CB-generated page. What is clear though is that the issue only arose after changing from K6.3 to K6.4 so I assume it's something that has changed between those to versions that is causing this.
To date the live production site still has K6.3 and it's possible to view user profiles without problems. I could send you a login to the development site if you think that would be useful.
1 year 6 months ago #233320 by Pinkeltje
Tested it and can't reproduce. What are you doing exactly? I suppose you first went to Kunena dashboard after updating to K 6.4?
1 year 6 months ago #233321 by btc
After encountering the problem I went to the dashboard and ran the diagnostics. It didn't find anything. But the problem persists.
1 year 6 months ago #233322 by Pinkeltje
No, after updating from K 6.3.10 to K 6.4.2 you first should go to Kunena dashboard. Did you do that?
Time to create page: 0.192 seconds
