This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Question Kunena Jomsocial 'My forum posts'
12 years 4 months ago - 12 years 4 months ago #157607 by sanneh
Hey.
I'm using Kunena 3.05 and jomsocial 3.1.
I have integrated kunena profiles with jomsocial, when you click on someone's name in the forums, you go to their JS Profile.
Also, any activity in the kunena forum is also posted to JS activity stream.
So far so good, we have everything working.
I noticed then, that usually u can see all the posts/topics made by the user, but this was missing since we are using JS profiles.
So I found the plugin 'My Forum Posts'
Display forum posts in my JomSocial profile.
This should be it right? But when I activated it and set as core file nothing seems to change in the JS user profile page...
What is the problem, why doesn't it work? This is the last piece of puzzle to a fully operational site I would be glad for any kind of help to resolve this!
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 4M
Joomla default template details : jsn_metro_pro | author: JoomlaShine.com | version: 1.0.0 | creationdate: Unknown
Kunena default template details : JSN Metro | author: Joomlashine Team | version: 2.0.0 | creationdate: 09/24/2013
Third-party components: Jomsocial 3.1.0.2
Plugins: Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
Last edit: 12 years 4 months ago by sozzled. Reason: Remove spoiler from configuration report
12 years 4 months ago #157609 by sanneh
I noticed outdated plugins in the CR. But I can't find them on my site to delete them...?
www.kunena.org/forum/154-Miscellaneous-o...dated-plugins#157608
12 years 4 months ago #157646 by Matias
Just go to the Extensions manager and hit "Manage". You will be able to filter the extensions by the type (plugin) and by the name (kunena).
