This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Solved K 3.0.0: JomSocial integration: avatar issue
12 years 6 months ago #149232 by sozzled
The download page contains the latest versions available for download. You should also subscribe to our official announcements and news category to be kept up-to-date about Kunena.
12 years 6 months ago #149235 by perryworld
Do you know which file we would find the following line of code in:
<a class="kwho-user" href="/my-profile.html" title="View potsie's Profile" rel="nofollow"><img class="klist-avatar" src=" powderclouduk.online-communities.info/co...ssets/user_thumb.png " alt="xxxxx's Avatar" style="max-width: 36px; max-height: 36px">
We are hoping to hack the href and change it to go to the Jomsocial profile page passing the avatar's user-id and name so it will end up like this
href=" powderclouduk.online-communities.info/my...ofile/339-xxxxx.html
Thanks for all your help so far
Cheers
Richard
12 years 6 months ago #149237 by sozzled
It all depends on what version of Kunena, the Kunena add-ons you may be using, the version of Joomla you are using, the version of JomSocial you are using, and whether you are still using the outdated and unsupported add-ons JomSocial - My Kunena Forum Menu 2.0.4 and JomSocial - My Kunena Forum Posts 2.0.4 that were referenced in the configuration report that you gave us in msg #3 above.
As far as I know, these problems do not exist in the latest versions of JomSocial or Kunena or the add-ons that are now supported by JomSocial.
Perhaps another member of the community can verify if the information I have given you can be corroborated? Did you read the sticky topic in this category?
12 years 6 months ago #149321 by perryworld
Hi Sozzled,
We have upgraded our version of Kunena to version 3.0.2 and that solved the problem
Thanks for your help
Richard
Time to create page: 0.216 seconds
