This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Solved K 3.0.0: JomSocial integration: avatar issue
13 years 1 month ago #149200 by perryworld
We have recently upgraded to 3.0 and have found an issue with the integration.
When we used to click on a users avatar in the forum it would take us to that users profile information in jomsocial.
Now when we click on the avatar it does take us to the jomsocial profile page but displays thue logged in users profile information and not that of the avatar we clicked on.
Is there a setting somewhere that enables this.
Any help would really be appreciated.
Richard
13 years 1 month ago #149210 by sozzled
perryworld wrote: Is there a setting somewhere that enables this?
I do not know, Richard. What are your current settings?
13 years 1 month ago #149219 by perryworld
Does this help?
Richard
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : gk_black_and_white | author: GavickPro | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Third-party components: Jomsocial 2.8.4
Plugins: Content - Kunena Discuss 3.0.0 | JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4
Modules: Kunena Latest 3.0.0 | Kunena Stats 3.0.0 | Kunena Search 3.0.0
13 years 1 month ago - 13 years 1 month ago #149221 by sozzled
Yes, thank you. That helps a lot. ;)
K 3.0.0 is unsupported (and so are the out-of-date Kunena add-ons that you are using). I believe these problems were fixed in the latest releases of Kunena and the add-ons used by you.
You also might like to look at the sticky topic in this category for extra information that might help you with JomSocial-related matters.
BTW - your version of Joomla is also very out-of-date, too. It would be worth your while attending to updating your site components. B)
Last edit: 13 years 1 month ago by sozzled.
The following user(s) said Thank You: perryworld
13 years 1 month ago #149224 by perryworld
Thanks sozzled,
Will take a look
Cheers
Richard
13 years 1 month ago #149231 by perryworld
Hi Sozzled,
We thought Kunena 3.0.0 was the latest version.
The add-ons where installed at the same time as we installed Kunena 3.0.0
What versions should we be using ?
Richard
