This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Solved Auto-update problems with JomSocial add-ons
13 years 3 months ago #147102 by Shimei
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : rt_stratos | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party components: Jomsocial 3.0_RC2
Third-party SEF components: sh404sef 4.1.0.1559
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1
I'm getting the following error as viewed in the first screenshot, after clicking it the second error arises. This has occurred after installing Jomosocial 3 RC 2, when I try to update the plugins there's an error. The icon in the meantime only goes directly to plugins which cannot be updated.
13 years 3 months ago #147112 by Jiminimonka
Jomsocial 3 has been released now. Have you tried using that?
Jomsocial are responsible for the update of the Kunena Group Plugin now, I don't the version 2.0.3 which is for Kunena 2, will work with Kunena 3 or Jomsocial 3.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: Shimei
13 years 3 months ago #147113 by sozzled
The first "error" that displays PLG_QUICKICON_KUNENA_ADDONS is the result of a symbolic name that has not been properly translated.
The second "error" is that there is no automatic update provided by Kunena for JomSocial.
There are several parts to this issue.
1) There are issues for the automatic updates with Kunena. A couple of case studies are documented here: Update from 2.0.4 ... directly to 3.0.1 or 3.0.0 first?
2) The Kunena team is no longer responsible for maintaining the add-ons that worked with K 2.0.4 and with JomSocial. This is explained in Kunena Group Plugin 2.0.4. Adding <p> Tags
3) This seems to be more of a problem for JomSocial.
4) The untranslated symbolic name PLG_QUICKICON_KUNENA_ADDONS may be the result of a missing element in the language file.
5) There could be issues involving sh404SEF that you may need to explore with the developers of that product. (See Interoperability with other Joomla extensions
13 years 3 months ago #147115 by Shimei
Thanks team!
I installed Jomsocial 3. And uninstalled the plugins. The plugins included with Jomsocial 3 are for version 2.03 Kunena. It does seem to be their problem, but I uninstalled all three and will just tough it out without them.
Time to create page: 0.145 seconds
