Question Error: pat-Error Could not load templates from header.html.
Only if I install language file (germaninformal or germanformal) in components/com_kuena I get an error. The language files for adminintrator/components/com_kuena are ok. I tested it with the file, which I found here templates.webdesign-welt.de/downloads.ht...iewcategory&catid=28
I deinstalled and installed kuena 1.5.3 several times. If I deinstalled it I get the error: JFTP::login: Unable to login and in line under it: Deinstallation was sucsessful. I have an testaccount at alfahosting.
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
- grumblemarc
- Elite Member
I changed the header and footer php files as instructed but it still does not work.
I do not know about the translation files. I only want English and used the "com_kunena_v1.5.3_stable_b1688_2009-06-15.zip" for my install.
"I get the error pat-Warning: Template 'kunena-header' does not exist." now.
any further information on correcting this?
NM- I actually got this fixed by deleting my old DB entries from when I had an earlier install of Fireboard. I know this wont help a lot of you but hopefully it will help someone.
