Question Error: pat-Error Could not load templates from header.html.
17 years 5 months ago #19925 by jdgf
I have installed kunena 1.5.3 without trouble; in backend there is all working. If I will work with kunena in frontend, I get this error:
Do you know a solution?
Regards,
Dietmar
17 years 5 months ago #19935 by xillibit
it's a problem during the install when Joomla uncompress the Kunena files. I suggest you to re-upload the file ou the files concerned by this problem.
17 years 5 months ago #19941 by grumblemarc
This is a problem with the Kunena template. YOu have uploaded one but the directory structure is incorrect. You have a folder in a folder. In rare instances language files cause this.
17 years 5 months ago - 17 years 5 months ago #19943 by Matias
FYI:
Small fix needed for: default_red, default_green, default_gray
Go to components/com_kunena/template/default_XXX directory and edit both header.html and footer.html
Change name in the first line from "jb-header" to "kunena-header"
Change name in the first line from "fb_footer" to "kunena-footer"
Last edit: 17 years 5 months ago by Matias.
17 years 5 months ago #19944 by grumblemarc
This is a new error for 1.5.3 then? I need to add it to my list of errors then.
17 years 5 months ago #19946 by Matias
Another one is this:
Call to undefined method CKunenaTools::isjoomla15() in some servers
Add following to components/com_kunena/class.kunena.php line 341:
function isJoomla15() { return true; }
