Solved Kunena 6 has not UTF8 in Greek Language
3 years 6 months ago - 3 years 6 months ago #227574 by xillibit
it seems there are is still issues in some languages files i will check later
P.S. : can-you make your screenshot larger to let me see the exact place where it has been taken ?
Last edit: 3 years 6 months ago by xillibit.
3 years 6 months ago - 3 years 6 months ago #227575 by sentiogr
Yes, off course!
Check the photos attached!
Last edit: 3 years 6 months ago by sentiogr.
3 years 6 months ago - 3 years 6 months ago #227576 by xillibit
To test i have installed here the greek language for Joomla! and Kunena, the one for Kunena is from the developpement version. You can try it too by yourself by changing the language in your Kunena profile here
I can't see the issue with Aurelia template on datetime :
3 years 6 months ago - 3 years 6 months ago #227578 by rich
Please go to:
/components/com_kunena/language
and
/administrator/components/com_kunena/language
Check, if there are folders named el-GR.
If yes, rename these folders and check whether the language is correct now.
When it's ok, you can remove these folders.
Last edit: 3 years 6 months ago by rich.
3 years 6 months ago #227580 by sentiogr
Please go to:
and
I checked and i didn't found any folder with el-GR!!
I downloaded the "pkg_kunena_languages_v6.0.9.1_2023-02-22.zip" file, installed again but neither then i found any el-GR in "/components/com_kunena/language" and "/administrator/components/com_kunena/language"... i only have folder en-GB.. is this wrong?
3 years 6 months ago #227581 by rich
That is correct. If you had found those folders there, it would have been a mistake.
I have now uploaded a Greek language zip file for you. You can install this via the Joomla Installer. Afterwards empty the Joomla and Browser cache and test your page.
The following user(s) said Thank You: sentiogr
Time to create page: 0.296 seconds
