Solved Kunena 6 has not UTF8 in Greek Language
3 years 2 months ago #227566
by sentiogr
Kunena 6 has not UTF8 in Greek Language was created by sentiogr
I found a problem with Kunena 6 and Greek Language..
It does not support UTF8..
Can you fix it?
Can you fix it?
3 years 2 months ago #227567
by rich
Replied by rich on topic Kunena 6 has not UTF8 in Greek Language
Thanks for reporting. I have added it to our error list.
3 years 2 months ago #227568
by xillibit
Replied by xillibit on topic Kunena 6 has not UTF8 in Greek Language
I have made a change : github.com/Kunena/Kunena-Forum/commit/7a...248620bb4786f6f1ffa4 , can-you check it please ?
3 years 2 months ago #227569
by sentiogr
How can i install your edited language file to my kunena?
Thanks a lot!
Replied by sentiogr on topic Kunena 6 has not UTF8 in Greek Language
Yeah i checked the differences and it looks very good now!Hello,
I have made a change : , can-you check it please ?
Thanks a lot!
3 years 2 months ago #227571
by xillibit
Just download them from attachments here and replace them on your language folder, the file el-GR.com_kunena.ini is for frontend and the other one is for backend
The following user(s) said Thank You: sentiogr
3 years 2 months ago #227573
by sentiogr
Thank you for your immediate response..
But i still have problem with language... not exactly with translation, but with the time display!
Please find attached images for your kind perusal.
Time to create page: 0.322 seconds
