Question avatar upload problem
16 years 9 months ago #37942 by fedbear
Hello. I am still using Fireboard but the problem that I have is a general one. So I hope I can still get your help from here.
The problem is related to permissions set by my server host. I don't know what they did but now my users couldn't upload avatars. When they tried to upload their own image file, it did not resize, and there was the following error message:
Warning: getimagesize() [function.getimagesize]: open_basedir restriction in effect. File(/home/eeeiceu/tmp/phpq2OuMh) is not within the allowed path(s): (/home/bearplac/:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/bearplac/public_html/mycommunity/components/com_fireboard/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 375
Warning: getimagesize(/home/eeeiceu/tmp/phpq2OuMh) [function.getimagesize]: failed to open stream: Operation not permitted in /home/bearplac/public_html/mycommunity/components/com_fireboard/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 375
Warning: imagecreatefromgif() [function.imagecreatefromgif]: open_basedir restriction in effect. File(/home/eeeiceu/tmp/phpq2OuMh) is not within the allowed path(s): (/home/bearplac/:/usr/lib/php:/usr/local/lib/php:/tmp) in /home/bearplac/public_html/mycommunity/components/com_fireboard/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 458
Warning: imagecreatefromgif(/home/eeeiceu/tmp/phpq2OuMh) [function.imagecreatefromgif]: failed to open stream: Operation not permitted in /home/bearplac/public_html/mycommunity/components/com_fireboard/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 458
Warning: imagedestroy(): supplied argument is not a valid Image resource in /home/bearplac/public_html/mycommunity/components/com_fireboard/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 509
Your avatar has been uploaded....
Any help would be greatly appreciated!
Feddie
16 years 9 months ago #37948 by xillibit
Replied by xillibit on topic Re:avatar upload problem
check the permissions of your directories on your joomla! installation, check by doing this help -> system info -> Directory Permissions
16 years 9 months ago #37978 by fedbear
Replied by fedbear on topic Re:avatar upload problem
Hi. I checked. All folders are writable. What else should I do?
16 years 9 months ago #38012 by xillibit
I advise to upgrade at least to Kunena 1.0.11, after some search this issues doesn't comes from to a permissions problem, but just a security protection with php functions. So, maybe this has been changed into Kunena 1.0.11.
16 years 9 months ago #38037 by fedbear
Hi. Thank you for checking out for me! I'd like to migrate to Kunena. My current FB version is 1.05. Can I migrate to the latest version of Kunena? I have read your post to other member regarding migration. It seems hassel free. But I am still a bit concerned as my site recently has a lot of problems and the forum is the only place left unharmed (until the avatar problem). I will read the documents. Would you be able to help me if I have any problem during migration? Thanks!
16 years 9 months ago #38038 by fedbear
Hi. I also noticed that all emoticons disappear. All these problems occur after some permission problems caused by my server host (I also couldn't upload photos in Jomsocial). Do you know if the emoticons problem is due to permission? Many thanks!
