Question problem with fireboard and adsense
16 years 10 months ago #19351 by marcolav
Hell
I have installed FB 1.0.4 and I am having problems with inserting adsense in posts or anywhere on the site, I have created positions fb_msg_1 / fb_msg_2 etc but nothing shows.
Then I have tried the hack posted at
www.dart-creations.com/joomla/joomla-tip...la-1.5.html#josc1978
but it is not working either in that the page just loses all the graphics part
however I noticed that the code in my default template looks slightly different than what is posted on that hack, it is the lines in bold below. Anybody has nay suggestions please?
thank you!
Marco
<?php
<?php
if (mosCountModules('fb_msg_1'))
<?php
if ($mmm == 1)
<div class = "fb_msg_1">
<?php
mosLoadModules('fb_msg_1', -2);
</div>
<?php
16 years 10 months ago #19352 by grumblemarc
Why did you install such an old version? The first thing people are going to tell you is to upgrade.
16 years 10 months ago #19357 by marcolav
Well, it came packaged with the Rockettheme template I used...
So there is no solution other than upgrading?
Marco
16 years 10 months ago #19358 by marcolav
Btw, I downloaded 1.0.5RC2 and the result is the same, except when I add the raw google adsense code the forum doesn't have a fit, yet the ad is not showing....
16 years 10 months ago #19362 by grumblemarc
What I meant was you might want to upgrade to Kunena. There is no more Fireboard and I wasn't aware RT was still making FireBoard templates. So you're working with obsolete extensions and templates. More than likely that FB template will not work with Kunena anyway.
Also what is the method you are trying to add Adsense? The preferred and easiest is to install an Adsense module and publish it to a module position.
16 years 10 months ago #19363 by marcolav
I am indeed trying to publish adsense to a module position, however it is being ignored ..., that is why I tried adding the raw code , but without result, I will backup and try to add Kunena and see what happens, unless there is a way to add adsense to this FB install, I really like the looks of it btw...
