Question Warnings and Notics after upgrading to 1.0.10
16 years 11 months ago #16847 by beat
xillibit wrote:
I have a way to fix it, in the file components/com_kunena/kunena.php at line 247 replace, but i think this solution work only on Php 5 :
$kunenaProfile->trigger('onStart', &$params);
by
$kunenaProfile->trigger('onStart', $params);
and line 1021 :
$kunenaProfile->trigger('onEnd', &$params);
by
$kunenaProfile->trigger('onEnd', $params);
Yup, strange that we didn't see that notice...
That works for php4 and php5 too, as long as the called function has the & .
Beat B)
CB Team
16 years 11 months ago #16851 by riswan13
i got this warning too
16 years 11 months ago #16894 by alexdgreat
I have the following problem with my Kunena installation.
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /www/xxxxxxxxx/www/root/components/com_kunena/kunena.php on line 247
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /www/xxxxxxxx/www/root/components/com_kunena/kunena.php on line 946
What should I do to solve this? Thank you in advance for your help.
xxxxx - is the name of my site.
16 years 11 months ago #16897 by xillibit
There is a fix above
16 years 11 months ago #16900 by alexdgreat
Solved with the upper advice. Thank you very much. Respect for you.
16 years 11 months ago #17079 by lcascant
Thank you Beat it works great now!!!!
Lorena
Time to create page: 0.263 seconds
