Question Warnings and Notics after upgrading to 1.0.10
16 years 11 months ago #16728 by Dahoon
I got some warnings and notices after upgrading to Version 1.0.10
PHP Version = 5.1.6 / MySQL Version 5.0.70
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /xxx/xxx/xxx/xxxxxx.de/httpdocs/components/com_kunena/kunena.php on line 247
Notice: Object of class jbCategory could not be converted to int in /xxx/xxx/xxx/xxxxxx.de/httpdocs/components/com_kunena/lib/kunena.permissions.php on line 73
Maybe someone has the same warnings and notices or someone has a quick solution.
Kind regards
Dahoon
16 years 11 months ago #16730 by xillibit
I have seen the same errors, but i haven't solutions. I report to the DEVs, thanks for you report.
16 years 11 months ago #16740 by lcascant
I have more or less the same problem on line 247 and 946.
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /xxx/xxx/xxxx/xxxxx/httpdocs/components/com_kunena/kunena.php on line 247
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /xxx/xxx/xxxx/xxxxx/httpdocs/components/com_kunena/kunena.php on line 946
Thank you for your help!
Lorena
16 years 11 months ago #16804 by RichRawlings
Warning: Call-time pass-by-reference has been deprecated in /xxxxx/xxxxx/xxx/xxx/xxx/xxxx/xxxx/il/components/com_kunena/kunena.php on line 247
Warning: Call-time pass-by-reference has been deprecated in /xxxxx/xxxxx/xxx/xxx/xxx/xxxx/xxxx/il/components/com_kunena/kunena.php on line 946
il.usmjparty.org
PHP : 5.2.8
MySQL : 5.0.67.d7-ourdelta-log
Thanks for any help with this!
16 years 11 months ago #16821 by xillibit
I have a way to fix it, in the file components/com_kunena/kunena.php at line 247 replace, but i think this solution work only on Php 5 :
$kunenaProfile->trigger('onStart', &$params);
by
$kunenaProfile->trigger('onStart', $params);
and line 1021 :
$kunenaProfile->trigger('onEnd', &$params);
by
$kunenaProfile->trigger('onEnd', $params);
16 years 11 months ago #16825 by rawkey
Fixed it for me !
Time to create page: 0.260 seconds
