Question Problem with pagination, not working...
17 years 7 months ago #11650 by TheSaint
Thanks Soozled for your help..
It was the template... the only template that seems to work if the default_ex. all other templates have a problem with the pagnation...They don't seem to be able to create the link corectly..
Hopefully this will save others some frustration...
and hopefully someone will be able to fix it ..:-) because I do prefer the default_gray template..
17 years 7 months ago - 17 years 7 months ago #11651 by woonydanny
i think at the moment there is still alot of code/logic in the templates. So alot of fixes have been put in to the default_ex template so using other templates will generally mean a few bugs. Even when using default_ex it still references files from default template.
Planned for development i believe is a new template system whereby all the logic is taken out of the templates and put into the core and then templates will purely be colours and designs.
So hopefully when this happens down the track (no time specified, just when its done) errors like these between templates won't occur anymore.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
Last edit: 17 years 7 months ago by woonydanny.
