Question Problem with Upload avatar in 1.0.9 - with simple solution
17 years 1 month ago #11523 by bytebandit01
i can upload/update avatar with 1.0.8 with no errors.
however after upgrading to 1.0.9, i am now encountering errors everytime i try to change my avatar.
my forum setup is..
profile: community builder
avatar: kunena
cb 1.2 stable
k1.0.9
with this everytime a update avatar i get..
Fatal error: Cannot redeclare check_filesize() (previously declared in ..\components\com_comprofiler\comprofiler.class.php:948) in ..\components\com_kunena\template\default\plugin\myprofile\myprofile_avatar_upload.php on line 34
Fatal error: Cannot redeclare display_avatar_gallery() (previously declared in ..\administrator\components\com_comprofiler\comprofiler.class.php:975) in ..\components\com_kunena\template\default\plugin\myprofile\myprofile_avatar_upload.php on line 59
and the simple solution was that i commented the two functions mentioned: check_filesize() and display_avatar_gallery() around lines 25-59 in ..\components\com_kunena\template\default\plugin\myprofile\myprofile_avatar_upload.php
it worked for me. i can now upload/update avatar just like before with the k1.0.8
Time to create page: 0.210 seconds
