Question greater than > and less than rectly
17 years 1 month ago - 17 years 1 month ago #11342 by bytebandit01
1. this is the subject i posted
greater than > and less than < characters not displayed correctly
2. and this is the one shown inside the post
greater than &gt; and less than rectly
3. while this is the one listed in recent discussions
probably parsed differently.. thus not displayed correctly in each..:(
Last edit: 17 years 1 month ago by bytebandit01.
17 years 1 month ago #11380 by kmilos
I've had similar issues with upgrading from older versions of FB...
It looks like gt lt, quot, amp are stored in the database (at least in the old FB versions) instead of >, <, " and &. Is that the case with your message database as well?
Now, there are SQL queries in the FB/Kunena upgrade script that were supposed to correct these, but for some reason they didn't do anything for me.
17 years 1 month ago #11512 by Lintzy
Which Kunena version have you installed? Please use the newest stable one 1.0.9, many bugs were fixed.
17 years 1 month ago #11516 by bytebandit01
yes i remembered this issue with the old fb on my old site but now on my new site i did a clean install of kunena 1.0.8 and then upgradedto 1.0.9, the problem is still present.
even here in kunena.com, you can clearly see that < and > are not correctly displayed
17 years 1 month ago - 17 years 1 month ago #11518 by Lintzy
that is very strange, on my 1.0.9 installation, it works fine, with the code, i used yours one for test .
Where can I see this?
<tag> Kunena >=1.0.8
For me it works fine?
Last edit: 17 years 1 month ago by Lintzy.
17 years 1 month ago #11520 by Lintzy
Could it be, that your browser causes this wrong coding? (try encoding set to utf8)
Time to create page: 0.223 seconds
