Question Size images in post - is based on what?
17 years 7 months ago #8334 by grumblemarc
My understanding is that the autoresize feature resizes images according to the width of the post area of your forum so as not to break the layout.
17 years 7 months ago #8352 by webstudent
Images are resized to 90% of text area width if they are wider than 90% of the text area.
Text area width is 450px by default. This causes all images wider than 405px to be resized to 405px.
This behavior is quite weird ... Images should not be resized by force unless they are wider than the text area.
Solution 1: Only resize the image if it exceeds the text area.
Solution 2: Add new config settings for maximum image dimensions.
When the browser resizes an image the image quality is reduced quite a lot, so it's important not to auto-rescale images without a good reason.
17 years 5 months ago #15274 by pequeno74
One question...
The autoresize only works with uploading images? because in my forum, the images in external hosted (for example imageshack) don´t resize and broken the post.
Thanks.
17 years 5 months ago #15278 by johnnydement
No, it should work also with external
17 years 5 months ago #15281 by pequeno74
Don´t works for me. Is it neccesary configure anything?
Kunena 1.0.9
17 years 5 months ago #15413 by Matias
There is a configuration option for this.
I believe that it was Frontend / Textarea Width
