Question Rank images [SOLVED]
17 years 8 months ago - 17 years 8 months ago #8083 by pastuh
Rank images [SOLVED] was created by pastuh
I have problem. When i trying edit rank image, i cant find where is located.
And in this image u can see.. here nothing to change..
img113.imageshack.us/my.php?image=nonev.jpg
Also i cant create new rank with images, becouse list empty...
Help, how to set rank folder..
Last edit: 17 years 8 months ago by pastuh.
17 years 8 months ago #8088 by pastuh
Replied by pastuh on topic Re:Rank images [HELP]
Why here so many bugs :/
All the time only problems..
Everything need to change only in .php files..
Cry me a river...
17 years 8 months ago #8089 by pastuh
Ok..no help.. but fixed again.
Folder: /administrator/components/com_kunena
Opened: admin.kunena.php
Line: 1792
And changed from:
/components/com_kunena/template/'$fbConfig->template.'/images/'$mosConfig_lang.'/ranks
To this:
/components/com_kunena/template/MY_TEMPLATE/images/LANGUAGE/ranks
And worked :) But i still think this is bug. Becouse.. when u changing/creating new template need everything change. And automaticaly nothing detects..
17 years 8 months ago - 17 years 8 months ago #8172 by FinnDorian
Replied by FinnDorian on topic Re:Rank images [HELP]
this is not the right solution...
you don't have to change this, you just have to change your folder name...
The problem is, that you are using an english template with another language...
So for example I had to copy the folder:
/components/com_kunena/template/MYTEMPLATE/images/ENGLISH
and call it
/components/com_kunena/template/MYTEMPLATE/images/GERMANI
because I use language GERMANI (informal) and $mosConfig_lang will search the rank images in that folder...
But the next update should replace the code in /administrator/components/com_kunena to (line 1792-1799):
// **** is there a language image-pack? if not: standard ranks **** if (is_dir($mainframe->getCfg('absolute_path') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.$mosConfig_lang.'/ranks')) { $rank_live_path = $mainframe->getCfg('live_site') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.$mosConfig_lang.'/ranks'; $rank_abs_path = $mainframe->getCfg('absolute_path') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.$mosConfig_lang.'/ranks'; } else { $rank_live_path = $mainframe->getCfg('live_site') . '/components/com_kunena/template/default/images/english/ranks'; $rank_abs_path = $mainframe->getCfg('absolute_path') . '/components/com_kunena/template/default/images/english/ranks'; } // **** kill up to 4 letters to avoid missing folders like germani or serbian_lat **** for ($count = 1; $count<= 4; $count++) { if (is_dir($mainframe->getCfg('absolute_path') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.substr($mosConfig_lang, 0, -$count).'/ranks')) { $rank_live_path = $mainframe->getCfg('live_site') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.substr($mosConfig_lang, 0, -$count).'/ranks'; $rank_abs_path = $mainframe->getCfg('absolute_path') . '/components/com_kunena/template/'.$fbConfig->template.'/images/'.substr($mosConfig_lang, 0, -$count).'/ranks'; } }
So the ranks are loaded from the default folder (which only contains an english rank-set), if the actual template doesn't support an rank-set in the desired language..
Additional, if someone like me uses germani language it also searches in the german folder, not in a germani folder, that is stupid ;)
It looks for the last 4 letters now.
so please mark this thread as solved ;)
Last edit: 17 years 8 months ago by FinnDorian.
17 years 8 months ago #8205 by kmilos
Replied by kmilos on topic Re:Rank images [HELP]
Is there a way we can make this a bit more generic, why only look at the last letter?
For example, we have serbian and serbian_lat, and it would make sense to look in the other if one is not present, both ways.
17 years 8 months ago #8242 by grumblemarc
Replied by grumblemarc on topic Re:Rank images [HELP]
Yes. I wondered why no one else had ever reported having any problems of this nature. Thank you.
