Question Rank images [SOLVED]
And in this image u can see.. here nothing to change..
img113.imageshack.us/my.php?image=nonev.jpg
Also i cant create new rank with images, becouse list empty...
Help, how to set rank folder..
All the time only problems..
Everything need to change only in .php files..
Cry me a river...
Folder: /administrator/components/com_kunena
Opened: admin.kunena.php
Line: 1792
And changed from:
/components/com_kunena/template/'$fbConfig->template.'/images/'$mosConfig_lang.'/ranks
To this:
/components/com_kunena/template/MY_TEMPLATE/images/LANGUAGE/ranks
And worked
- FinnDorian
you don't have to change this, you just have to change your folder name...
The problem is, that you are using an english template with another language...
So for example I had to copy the folder:
/components/com_kunena/template/MYTEMPLATE/images/ENGLISH
and call it
/components/com_kunena/template/MYTEMPLATE/images/GERMANI
because I use language GERMANI (informal) and $mosConfig_lang will search the rank images in that folder...
But the next update should replace the code in /administrator/components/com_kunena to (line 1792-1799):
Additional, if someone like me uses germani language it also searches in the german folder, not in a germani folder, that is stupid
It looks for the last 4 letters now.
so please mark this thread as solved
Is there a way we can make this a bit more generic, why only look at the last letter?
For example, we have serbian and serbian_lat, and it would make sense to look in the other if one is not present, both ways.
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
this is not the right solution...
Yes. I wondered why no one else had ever reported having any problems of this nature. Thank you.
