Question Open in Parent Window With Browser Navigation not working properly
17 years 9 months ago #6469 by Gibbo
Hey All, I have set my Kunena forums up ok on my joomla installation, but I have one problem trying to use it.
when I select "Open in Parent Window With Browser Navigation"
I get the result below, I have cropped out the header image that also appears:
I wish to have it take up the whole width of the screen without the header or side menu showing.
The only setting that does that is the new windows without browser navigation, bit I dont want a new window.
this is a fresh uninstall of joomla and kunena. Im using the free Auto Mania 2 Joomla template.
thanks in advance.
17 years 9 months ago - 17 years 9 months ago #6515 by sozzled
G'day, mate :laugh: Interesting concept: open a new page without giving your users the opportunity to navigate to other parts of the site. :unsure: It kind of defeats the purpose of having a site template, doesn't it? :huh:
I've not seen what you're trying to attempt before. Have you got an example site where this behaviour occurs?
Perhaps the problem lies in your choice of template: have you considered using a template that doesn't have a vertical-style menu but has a horizontal menu, say at the top or bottom of the page (like the one here at www.kunena.com )?
There's another alternative: create two Joomla sites, one for your usual stuff (using the "Auto Mania 2" template) and the other site for your forum using a different template - with a backlink to your main site. The menu item on your main site would link to the second site. Of course, your users would have to login to the second site, but that's your problem. That's one way to employ different template themes.
Good luck with this. I think you're heading into unchartered territory ... :cheer:
Last edit: 17 years 9 months ago by sozzled.
17 years 9 months ago #6518 by Gibbo
Thanks for the reply.
the pic above only really shows a small part of the screen. Here is the full SS:
What I dont like is the fact that the forum seems squeezed into a tiny space, I wanted to get rid of the side menu to give the forum more width across the screen.
People can still use the menu @ the top when they want.
Can this be achieved?
Thanks.
17 years 9 months ago - 17 years 9 months ago #6521 by nzjacob
Thanks.
Yes .. you need to change the settings for when the two modules on the left appear.
This is done in the module manager at the back end of Joomla.
Change these modules to "Select Menu Items from List" and unhighlight Forums (or whatever you called the Forums).
Once you have done this, you will just have to remove the header part .. this might be trickier, but at least your halfway there.
Last edit: 17 years 9 months ago by nzjacob.
17 years 9 months ago - 17 years 9 months ago #6522 by sozzled
D'oh! Of course! :pinch:
Don't assign a menu to appear on your forum page (as described in nzjacob's) reply! Now I've gotta live down the fact that I've been upstaged by a kiwi ... unngghh! :blush:
Make sure your top/horizontal menu has a link back to your home page, otherwise you'll leave your users stranded with only their back button to guide them.
17 years 9 months ago - 17 years 9 months ago #6523 by Gibbo
Thanks for that, great information!
I have now removed the menu items from the left, but the forum STILL takes up the same small space it did before!
Is there another setting somewhere that will make it take up the whole width?
OR is there a good template editor I can use to ake the template full screen instead of hogging the middle of the page?
Thanks again.
Last edit: 17 years 9 months ago by Gibbo.
