Question Big fugly space needs to go!
17 years 6 months ago - 17 years 6 months ago #8001 by jekl
Hey moof!
I´ve seen you managed to fix that problem.
Is it another template now, or how have you done that.
I have the same problem and can´t get rid of it.
Any hints?!
Thx
jekl
<edit>
it is definitly the div id left, but i have no clue what to do to fix it.
unfortunately i´m not that experienced with css, so i tried everything. But nothing worked
</edit>
Last edit: 17 years 6 months ago by jekl.
17 years 6 months ago - 17 years 6 months ago #8002 by jekl
Oh Boy! Solved :laugh:
Sometimes you try for hours, post a thread in the forum and the next thing you do works....
#Kunena .fb_list_top {
new: clear:none;
was: clear:both;
After that igot the same problem with the fb_list_bottom. So i also needed to edit
#Kunena .fb_list_bottom {
new: clear:none;
was: clear:both;
@gn0101: are you sure you changed the value of #Kunena .fb_list_actions, not the #Kunena .fb_list_top?!
Thx anyway ;)
Time to create page: 0.238 seconds
