Question Different a:link color for 'Active Topics' section?
That said, I do have one problem remaining: Although the blue (#006699) a:link color works fine elsewhere thoughout the forums, this color is barely viewable against my forum's dark green background when viewing the "Active topics in last 720 hours" section (the '4 hours', '8 hours', '12 hours, etc. links).
If I modify the a:link color to be lighter color, it affects all the forum's other links, making them barely viewable. So what I need is a way to change the a:link color for *only* that section (if that is even possible).
Ideas?
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
Based on your reply, I will assume that what I asked can be done. But as mentioned, I know nothing about writing CSS code so it is beyond my expertise how to "add a selector just for that one element".You'll have to add a selector just for that one element.
Perhaps you could post some example code to do this that I could work from?
Thanks!
- woonydanny
- Elite Member
- Thank you received: 22
In CSS, selectors are used to declare which elements a style applies to, a kind of match expression. Selectors may apply to all elements of a specific type, or only those elements which match a certain attribute; elements may be matched depending on how they are placed relative to each other in the markup code, or on how they are nested within the document object model. en.wikipedia.org/wiki/Cascading_Style_Sheets
so my understanding is what you need to do is to make a new style in your css and then apply that style to the Active Topics text
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
- grumblemarc
- Elite Member
Here is a link to an excellent video tutorial on FireBugs usage.
www.litfuel.net/plush/?postid=161
Somehow I guess I thought it would be a matter of adding a couple of simple lines of code (simple for those who know CSS) but evidently I was wrong. I realize you're not here to teach CSS, so my apologies if I was out of line for asking.
I guess I will make due with what I have now. It, frankly, wouldn't make sense for me to sit down and learn to code CSS in order to change this one thing.
Thanks again.
